Home Link
Old Dec 8, 2009 | 10:41 AM
StickShifty's Avatar
StickShifty
Default Home Link
anyone have the link to the Home Link install thread. i cant find it in the Stickies and its not showing up in the search results.
thanks
going to be my next mod.
Old Dec 8, 2009 | 11:48 AM
partsbill's Avatar
partsbill
Any Ford, Mercury, or Lincoln vehicle with the homelink unit in the visor will work, you can pick one up cheap at a junk yard or I've even seen them on ebay, only 2 wires used on the unit I installed out of the town car, the unit had a green with red stripe wire which I connected to the white with blue stripe wire for power, then it was black to black for the ground, tricky part was cutting the hole in the console, I removed the face plate from the homelink unit then traced the outline on the console as close to the edge as I could so there would be enough room for the unit inside, after I traced the outline I drilled a 1/2" hole in the center of the outline , then I used my dremil with a round sanding drum attachment to sand up to the line that I traced, I sanded alittle at a time and tried the face plate in the hole until it fit snug, then I attached the face plate back to the unit and installed it in the console, I used a piece of foam to wedge in between the unit and the plastic bar in the console that you'll see so that when you push on the buttons the unit doesn't move. be careful when making your hole in the console, if you make a mistake a new console with the intruder sensors retails for $490.87, it took me about a 1 1/2 hours to do taking my time but it turned out great and looks like a factory install.
Bill
I already know this thread is usless without pics, but when I did mine 2 years ago I didn't take any, just a picture of the finished job.
Old Dec 8, 2009 | 11:52 AM
douglasland's Avatar
douglasland
Why can't we replace the mirror with something like?
http://cgi.ebay.com/ebaymotors/ws/eB...m=140284363941
Old Dec 8, 2009 | 11:58 AM
partsbill's Avatar
partsbill
that's a great price, the one from Ford retails at $464.29, my homelink install was free, I removed the unit from a visor that we replaced under warranty out of a town car here at the dealer that I work at, only thing wrong with the visor is that it was ripped, you can find visors on ebay for around $25.00, also your local junk yard.
Old Dec 8, 2009 | 12:13 PM
StickShifty
Bill
how does the programming work?
Old Dec 8, 2009 | 12:26 PM
partsbill's Avatar
partsbill
1. Verify the hand-held transmitter is operative.
2. Prepare for programming the universal transmitter. Erase all 3 channels by holding down the 2 outside buttons until the red indicator begins to flash (20-30 seconds). Release both buttons.
3. Select 1 of the 3 universal transmitter channels to be programmed by pressing the desired button.
4. Hold the end of the hand-held transmitter 25-51 mm (1-2 inches) from the front surface of the universal transmitter so that the red indicator can still be seen.
5. NOTE: For Canadian vehicles only: during programming, the hand-held transmitter may automatically stop transmitting after 2 seconds, which may not be long enough to program the universal transmitter. If programming this type of hand-held transmitter, continue to hold the button on the universal transmitter while re-pressing the hand-held transmitter button every 2 seconds.
Use both hands to press the hand-held transmitter button and the desired button on the universal transmitter. Do not release either button.
6. Hold down both buttons until the red indicator on the universal transmitter flashes, first slowly and then rapidly. Release both buttons when the rapid flashing begins. The universal transmitter has successfully learned the new frequency signal and can be used in place of the hand-held transmitter(s).
7. NOTE: A code-protected or rolling-code garage door opener may require further programming. For additional information, refer to Training a Garage Door Opener Equipped With Rolling Codes in this section.
To operate, press the appropriate button on the universal transmitter. The red indicator is on while the signal is being transmitted.
8. To program additional hand-held transmitters repeat steps 3-6.
1. Program the hand-held transmitter to the universal transmitter.
2. Train the garage door opener receiver to recognize the universal transmitter.
1. Remove the cover panel from the garage door opener receiver.
2. Locate the training button on the garage door opener receiver. Location and color of the button may vary by manufacturer. Refer to the garage door opener instruction manual or Owner's Literature.
3. Press the training button on the garage door opener receiver for 1-2 seconds.
4. Press the programmed universal transmitter button for as long as the universal transmitter red indicator flashes (1-2 seconds). Release the button and re-press the button to confirm that the universal transmitter is trained to the receiver.
5. The garage door opener should recognize the universal transmitter.
Erasing Channels
1. NOTE: Individual channels cannot be erased, but can be reprogrammed using the procedures for programming. For additional information, refer to Universal Transmitter Programming in this section.
To erase all 3 programmed channels, hold down the 2 outside buttons until the red indicator begins to flash (20-30 seconds). Release both buttons.
Old Dec 8, 2009 | 12:46 PM
StickShifty
i just grabbed one off ebay. it says its from a Jag, but it looks like a Ford sun visor. i am assuming it will still work. a homelink unit is a homelink unit and the only difference is the visor, i hope. it still should have 2 wires, one feed and one ground.
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
popsotto
Sep 28, 2015 06:58 AM
