Question about wiring interior lights
Old Dec 13, 2009 | 01:14 PM
Shadow7874's Avatar
Shadow7874
Default Question about wiring interior lights
Im considering adding some red accents to go with the my color but i want them to turn on when the my color does (headlights).
Does anyone know how i can splice into that? I plan on having it turn on when the gauges are red but also having a switch to turn back off when ever i feel like it
Old Dec 13, 2009 | 01:41 PM
elmo3000's Avatar
elmo3000
subbed!
Old Dec 13, 2009 | 03:00 PM
rford426's Avatar
rford426
I wired mine to the dimmer on the mycolor that way you can dim them if you dont want them as bright!
Old Dec 13, 2009 | 05:08 PM
HypromanGT's Avatar
HypromanGT
157db to the rescue on this one, me-thinks. It's most-likely all handled by the SJB, and I have a feeling it isn't going to be easy...
Old Dec 13, 2009 | 05:42 PM
rford426's Avatar
rford426
I think I did mine to a white wire with yellow stripe not + though...
Old Dec 14, 2009 | 12:48 AM
Shadow7874's Avatar
Shadow7874
will the dimmer work with neons? (whispers to avoid the inevitable flaming)
Old Dec 14, 2009 | 01:22 AM
danzcool's Avatar
danzcool
Nope.
I think there is a spare leg of the wiring harness under the center console that has 12v when the lights are on.
Old Dec 14, 2009 | 11:09 AM
rford426's Avatar
rford426
They should mine were cold cathodes got em for like 9 bucks but they work great! But they should work with the dimmer i don't see why they wouldn't
Old Dec 14, 2009 | 11:29 AM
157dB's Avatar
157dB
Cut & Paste Expert
You can tap off of the headlight switch illumination wire.
Pin 2, C205
Yellow-Lite Blue wire
Nope, neons and cold cathodes are one and the same and
dont dim with decreased voltage input.
Old Dec 14, 2009 | 07:52 PM
rford426's Avatar
rford426
My cold cathodes dim with my dimmer
