I can't hook
Old Dec 15, 2009 | 09:50 AM
replica's Avatar
replica
Default I can't hook
After installing a tune my car doesn't really hook in 1st anymore. Even if I slowly roll into the throttle, once I get to WOT, I still spin. I still have the 3.31 gear and everything else is pretty much stock. I have the 17 inch bullitts with the Pzeros, 235's. Is it possible to hook well on the stock rims with a 235 tire? If not, how wide of a tire can I go with on the stock rim? Any cheap tire suggestions?
Old Dec 15, 2009 | 09:56 AM
loudnlow's Avatar
loudnlow
I have the same problem lol. Im not sure how wide we can go maybe 255.
Old Dec 15, 2009 | 09:57 AM
Nuke's Avatar
Nuke
I had the same issue with my stock BFG's after my CAI & tune. I went with a set of 275 Goodyear Eagle's. Problem solved. BUT, if I add any more power I'll definitely need some suspension mods.
Old Dec 15, 2009 | 10:02 AM
Riptide's Avatar
Riptide
Must be something about the altitude here but my car would hook from a roll no problem with stock pirellis and a 93 tune/intake + 4.10 gears.
Old Dec 15, 2009 | 10:20 AM
replica's Avatar
replica
Will 275's fit on 17's?
If so, MUY BUENO.
My car is all over the place. I can't get traction in first and with second gear I have to make sure the car is perfectly straight with no other loads on the suspension. I think I'm below sea level here in Houston.
Old Dec 15, 2009 | 10:24 AM
Riptide's Avatar
Riptide
I'm thinking ther 4600+ foot DA we run in up here is easily robbing the car of a good 25whp. Maybe even more. It sucks but it's all relative I suppose.
I can still spin if I dump the clutch. Also, some of it depends on the pavement. I've been able to spin before but it depends on what stretch of road I'm on.
Old Dec 15, 2009 | 10:36 AM
replica's Avatar
replica
I just floor it and I'm spinning. It's actually kind of annoying. My tires are in "ok" shape as well. Probably 50% tread.
Old Dec 15, 2009 | 10:44 AM
blk281gt's Avatar
blk281gt
Width will not help much. The only thing that will work is drag radials. I ran the M&H racemaster 275/50 17 on stock rims and they work real well. They are about 200 bucks each and work real well on the street also. Very soft though and depending how you use them, they are only goog for 12,000 miles or so. Dont waste your money on another street tire if traction is what you need.
Old Dec 15, 2009 | 10:47 AM
replica's Avatar
replica
Wow, so a 275 does fit?
sweet.
Riptide's Avatar
Riptide
Width does help but I agree the compound is more important overall. A narrow drag radial will probably hook better than a wide summer tire.
A 275 will fit the stock 17x8 but just keep in mind that it isn't approved for that size rim and it does bow out quite a bit.
