driving lights in-op
Old Dec 31, 2009 | 10:59 AM
gtbillyb's Avatar
gtbillyb
Default driving lights in-op
Hope you folks can point me in the right direction...last night turned on my headlights and then pulled out on the switch to activate the parking/driving lights..didn't come on..only when in the "parking light" position..then went the high beams and didn't come on ..no high beams..any ideas?..fuse maybe or what..thanks ahead of time..and "Happy new year"
Old Dec 31, 2009 | 11:18 AM
HeadonaStick's Avatar
HeadonaStick
Do you have aftermarket HIDs installed?
Do the high beams work with the fog lights off (low beams)?
Old Dec 31, 2009 | 11:31 AM
157dB's Avatar
157dB
Cut & Paste Expert
Do you have the dreaded water leak that causes these electrical gremlins?
Have you checked EVERY fuse that
pertains to the headlights/fogs?
Fogs dont work with the high beams OEM, by the way.
Get the owners manual out of the glove box (you do know where that is)
and check the fuses first.
Old Dec 31, 2009 | 11:45 AM
gtbillyb's Avatar
gtbillyb
Nope no water leaks..i'm aware the fogs don't work with the high beams..the fogs come on in the parking light pos..they go off when turning lights on..if i pull out on the switch..they stay off..and there are m\no high beams..the lights are all stock..thanks
Old Dec 31, 2009 | 12:19 PM
Nuke's Avatar
Nuke
I'm confused.
Pulling out on the switch turns on the fogs except in the "off" position. Turning the switch clockwise 1 click turns on the parking lights. 2nd position clockwise are the low beams and the parking lights. Our cars don't come stock with driving lights besides the headlights.
If they're not working that way, then check the fuses. But from your description it's sounding like the switch or an SJB issue.
djbigskrilla
Sep 20, 2022 01:04 AM
MustangGirl98
Aug 2, 2016 08:10 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
jjwinel78
Aug 17, 2015 03:34 PM
mweiland
Aug 16, 2015 10:59 AM
