Help! Engine Stuttering
I have a 2005 Saleen S281 (non-SC). In the mornings when I first crank it up and get on the road, especially when it's cold, it stutters very badly. It will have power for a couple of seconds then loose power for a half second and cycle through this for about a minute or so until the car is warmed up. This creates a very jerky feel as though I was rapidly cycling the throttle.
Any ideas what could be causing this?
I haven't done any aftermarket work to the vehicle besides appearance modifications. It's tuned by Saleen to run 91 octane, and I run 93 due to the lack of 91 octane in this area.
I'm thinking this can be either from a dirty throttle body or my TPS is going out. Anyone have any ideas?
In case you don't already know, don't buy regular old carb cleaner. Make sure it specifies itself as a Throttle Body cleaner. My car was doing something similar and when I cleaned the Throttle Body it stopped completely.
check the obvious things. spark plugs, ignition coils and give it a tune up. do other maintenance on it, coolant flush, replace the fuel filter, i don't know where the PCV valve is on a saleen but check that, etc. let us know what you find
+1 to everything previously mentioned.
also keep in mind that when you first start
a cold engine, the 02 sensors are not used
to maintain the air/fuel ratio. if you are
heading down the road before the 02 sensors
are operating, this may account for some
of the symptoms you describe.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
TfcCDR
Sep 14, 2015 12:08 PM
