Problems with tough clutch.
Old Jan 24, 2010 | 05:21 PM
luckydawg003's Avatar
luckydawg003
Default Problems with tough clutch.
Just wondering if anyone else notices how hard it is to push our clutches in while driving. I have to use a lot of strength and energy to push my clutch in, not sure if it is defective or its harder on all mustangs. When I drove other manual cars they seem to be a million times easier to push in.
Also with my mgw short shifter it takes a lot of force to get it into 1st, 2nd, 5th, and reverse gears. I think because of the springs in it. Is there any way to loosen the tension in it?
Old Jan 27, 2010 | 12:48 PM
luckydawg003
Anyone change their clutch to make it softer?
Old Jan 27, 2010 | 12:52 PM
gmoran1469's Avatar
gmoran1469
The only clutches I have felt that were soft were on older cars where the clutch had basically worn itself out. A stiff clutch isn't a bad thing.
Old Jan 27, 2010 | 12:56 PM
wilkinda's Avatar
wilkinda
2010 Section Moderator
my '05 Mustang GT was the same way. From what i understand they changed some things up in the '08 models and it's easier. Slickest shifting 'stang I have had by far is the new 2010 shown below.
Since you are in Brandon, Fl you might want to join up with a few of us that go cruising together. We are trying to make it a monthly thing. PM me if your interested...
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
