Delete Plates
Old Feb 10, 2010 | 05:35 PM
BAKnBLK2010's Avatar
BAKnBLK2010
Question Delete Plates
Please don't bash me for asking but I have no idea what delete plates are. I see them in some folks mods. I used the search function and couldn't find anything. So what are they???
Old Feb 10, 2010 | 06:45 PM
rydeordie's Avatar
rydeordie
You have to search Motion Delete Plates....me personally recommend them if you have a supercharger.
Old Feb 10, 2010 | 09:42 PM
thewarmachine's Avatar
thewarmachine
Charge motion plates are like a secondary throttle body with butterfly valves that open up wider under higher rpms and remain more closed under lower rpms. I believe they are supposed to create more torque in the low rpm range. If you drive your Mustang hard, you'll probably notice a big lunge when the rpms reach 3000. That's because the valves open up wide.
Delete plates are a replacement of this part but with no butterfly valves. It's just wide open all the time.
Old Feb 11, 2010 | 12:56 PM
Cusp's Avatar
Cusp
They are like the above poster said. They increase turbulence during low power usage increasing torque and economy. At high power they reduce the flow by being in the way even though they are fully open. Removing them will gain some top end power but will cost several MPG for all your other driving. Depending on your state emissions laws, having them removed could cause you to fail your inspection. Be happy if you live in a state which doesn't care about such things.
Old Feb 11, 2010 | 01:48 PM
BAKnBLK2010
Thanks for the replies!!
Old Feb 11, 2010 | 01:57 PM
Riptide's Avatar
Riptide
The delete plates from what I've read help keep combustion cleaner and get the fuel burnt more fully at idle and low rpms. They open up as you climb up in the revs.
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
mdg
Oct 1, 2015 07:04 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
