Shaker hood scoop?
Shaker hood scoop?
Apologies up front if this has been asked many times over: didn't find my answer using Search.
My interest has been piqued in getting a Mustang. That 2011 GT is gonna be sweet. Anyway, I love the look of the shaker hood scoop, going back to the '69 and '70 models. I don't think this is an OEM option, so who makes a shaker scoop that could be used on the current models? Would it require a whole new hood, or is it a matter of taking a sawzall to the stock hood?
Thanks in advance.
Thanks in advance.
Thanks Nutty. Glad you like it.
I just read an online article on the kit and installation, by Mustang Monthly. Looks exactly what I was wanting. Not cheap, but not exorbitant. Plus it is functional, which I definitely wanted.
This car could be a TON of fun!
I would debate that with you anytime... grinder with a good wheel cuts our hood like butter and is a smooth cut where as the vibration of the jig saw can create some awkward edges.... of course this is all pretty irrelevant considering they give a nice trim ring that covers your cut regardless....
I say eBay is your friend... I found mine there new about $275 cheaper than my favorite websites
And they are conversation pieces... everyone asks about it hood up or down... cruising or parked
Here, everything you need in that thread.
Use the stickys guys...
https://mustangforums.com/forum/2005...c-and-vid.html
I do a good bit of sheet metal work mostly with Aluminum and I have always found it easier and cleaner to use a jig saw (when you can't use a band saw). But what is most important is to use whatever kind of tool that works best for YOU.
When I cut the hole in my hood I varied from the printed instructions a bit, for one thing I cut through the template, hood, and blanket all at the same time instead of the printed method. I got no rough edges and perfect corners.
I've never done a hood scoop, but when using a jig saw put some bees wax on the blade to help with cooling and catching of some material. You could also have someone with an air nozzle blow away the material that is being thrown everwhere while you are cutting.
I got mine on eBay too in 2007, it was $450 or so I think. You just have to be patient and look for a good deal.
The Aluminum hood cut so quick it didn't have a chance to get very hot in my case. There was very little aluminum sawdust, most of which fell through to the moving blanket I had over the motor, then what ever I had left I blew off with an air nozzle like you did.
