What do I need to make my car do this?
http://www.youtube.com/watch?v=VlCzEOuIlJY
His Rpms drop so fast, It sounds so clean. Is it the NSR stage 2s, or the ud pulleys, or what?!? I want my car to rev like that. Or maybe its cause his car isn't warmed up in the video.
And don't get me wrong, I love the sound, but I wouldn't consider that "clean"." It also sounds if its echoing, so it might be in a garage.
well...recent studies are saying that it doesn't really hurt the engine to rev them cold as long as you're not redlining and holding them. They are built to be able to be crunk able and driven away, heat up faster and run harder. They are much better built then yesteryear engines...
Having full lubrication is one thing.
Not creating lots of differential expansion between parts that have been fit to small clearances is something else again.
OP - a light flywheel and clutch assembly will allow an engine to spool down quickly (less rotational inertia trying to hold the revs up).
So will greater backpressure than normal, rather than less (where do you think the energy to pump against the greater backpressure would come from?).
Norm
Norm
