Rear window louvers
Old Feb 21, 2010 | 06:26 PM
cfr865's Avatar
cfr865
Default Rear window louvers
How many have the plastic textured louvers and wish they had gone with the aluminum ones instead. I'm going to get some but trying to decide which ones to get.
Old Feb 21, 2010 | 06:44 PM
Nuke's Avatar
Nuke
I wasn't happy with the look of the ABS plastic rear window louvers and not sure how well they'd hold up to being painted. I picked the Astra-Hammond aluminum.
Old Feb 21, 2010 | 06:47 PM
2010V6Stang's Avatar
2010V6Stang
BEWARE! Possible Scammer
I also have the AH, painted flat black.
Old Feb 21, 2010 | 07:24 PM
07 Stang's Avatar
07 Stang
The aluminum ones are the best and if you get the ones with the hinge, it's even better. I had it on my '82 5.0 and loved the fact that you could easily clean the back glass.
Old Feb 21, 2010 | 08:04 PM
Deadbeat's Avatar
Deadbeat
I have Visus' rear louver (Bought from Cervini's) with the hinges. I absolutely love em!
I still have to buy the stand to prop it up so I can clean the back window easier.
Old Feb 21, 2010 | 08:17 PM
07 Stang's Avatar
07 Stang
I'm surprised that they didn't come with the louvers. Mine did....they folded up in the middle and had a clamp that held them into place. You had to unscrew the bolts on each side first, then lift the louvers and pull the props out. Took like 2 minutes, but well worth it to have a clean back glass. Not only that, but you could wipe down the inside of the louver as well.
Old Feb 21, 2010 | 08:28 PM
Deadbeat's Avatar
Deadbeat
Holy ****. I didn't even check, lol. I'll have to go outside and take a look. I usually put a thick towl on my roof and flip the louver over
It was kinda scary trying to unhinge them at first. The instructions didn't mention anything about the prop or how to unhinge, so it took me a little bit to figure it out, lol.
But thanks for letting me know. I was about to purchase the one from AM
Old Feb 21, 2010 | 08:33 PM
07 Stang's Avatar
07 Stang
Yeah check to see if they are there. The ones I had were from 1982, so they may be doing something different with them now.
Old Aug 26, 2010 | 03:14 PM
Alec's Avatar
Alec
There's a few plastic rear window louvers on craigslist around here for ~$100. Is the general consensus not to bother with the plastic ones?
Old Aug 26, 2010 | 04:40 PM
D'prived's Avatar
D'prived
I ended up getting the Astra Hammond aluminum louvers on Amazon for about $400.00. I went with the aluminum simply because I didn't like the way the plastic ones looked. IMO the plastic ones just look cheap. Plus they don't last near as long as the aluminum.
