engine build ??
Old Feb 24, 2010 | 04:03 PM
graygt07's Avatar
graygt07
Default engine build ??
well i think i am going to do it. the money just kills me....
brenspeed 302 shortblock $3299
cam (127ben2) $699
8 bolt flexplate (sfi) $350
10% overdrive crank $422.50
60# injectors $364
ford head gaskets $260
pan gasket $32.54
head bolts $89
phaser bolts $25
fluids $119.18
gt500 oil pump $63.95
2.8 saleen pulley $99.99
belt $62.99
labor total $ 1932.5
grand total $7819.60 wow that is a load of money
plus they said i will probably need the bigger heat exchanger for my saleen $450 plus labor
take a look and see if i missed anything?
more power more money
hope to be in the 10's at the track with this set up. i am guessing with the overdrive pulley and 2.8 i should see 15# boost and make around 540rwhp. think that is doable?
Old Feb 24, 2010 | 04:18 PM
americaniron's Avatar
americaniron
Smile
Quit bitching, and get her done. Sounds like a killer combo when done.
Old Feb 24, 2010 | 04:31 PM
distantsoldier's Avatar
distantsoldier
wow...the small things really add up too huh...
good luck with it. looks similar to a built I'll be doing in about 2-3 years
Old Feb 24, 2010 | 04:34 PM
tx_zstang's Avatar
tx_zstang
various other gaskets (timing cover, intake, valve cover, etc.); billet gears in the oil pump. Silicone/sealer (if not included in fluids)
I'd personally go with (and am doing in my build) arp head studs, but thats your choice, and at least the bolts for flexplate.
Will your fuel supply setup support this? (stock vs other)
Old Feb 25, 2010 | 06:46 PM
graygt07's Avatar
graygt07
i have the gt500 fuel pump system from brenspeed so that should be good.
Old Feb 25, 2010 | 06:50 PM
BruceH's Avatar
BruceH
What kind of auto do you have?
Old Mar 5, 2010 | 11:06 PM
graygt07's Avatar
graygt07
the stock auto
Nick Oliver
Oct 17, 2018 04:22 AM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
