Well I pulled the trigger!
Old Mar 10, 2010 | 11:49 AM
branman1's Avatar
branman1
Default Well I pulled the trigger!
So I have been looking at a set of springs for a while. Im very very picky when it comes to the stance of my cars. I believe that height/wheels on a car make or break the overall look. I decided to try the Roush springs http://store.roushperformance.com/detail.aspx?ID=1007. I am not going with shocks/struts right now as If i want them later I can just throw them in. The install will be no problem so I dont mind doing it twice if im really unhappy with the ride. The springs should be here tomorrow. Ill post pics after the install.
Old Mar 10, 2010 | 11:53 AM
Kona6Stang10's Avatar
Kona6Stang10
woot!
Old Mar 10, 2010 | 12:13 PM
dominant1's Avatar
dominant1
Nice pick you gonna get sway bars ? Hey Branman I just had Tillman install my Shaft masters aluminum drive shaft today... i was in and out in 90 minutes.. The place is closer then i thought, those guys love mustangs..
Old Mar 10, 2010 | 12:51 PM
WeinerDog's Avatar
WeinerDog
Tell us what you think of the DS.
branman, how much of a drop with those springs?
EDIT: Nevermind, I missed your link! That's about the same drop as with the Steeda sports.
Old Mar 10, 2010 | 01:20 PM
branman1's Avatar
branman1
Yeah i have seen pics of both springs installed on 2010 mustangs and it looks identical.
Old Mar 10, 2010 | 01:22 PM
branman1's Avatar
branman1
I may once I see how it rides. Yeah those guys are cool as hell. I had a great first experience with tillman when i had my tune done. What did they charge you for install?
Old Mar 10, 2010 | 02:08 PM
Blair's Avatar
Blair
I had a set of the Roush springs on my car. I had the blue stage 2 springs, but the extreme springs are very similar. Since the rears are progressive, your rear will probably be very bouncy on rough roads until you upgrade your shocks. Not unbearable, just a little annoying...
Blair
Old Mar 10, 2010 | 02:16 PM
wilkinda's Avatar
wilkinda
2010 Section Moderator
Blair
Unless you don't remove the factory bump stops..then it won't bounce at all. it will be like driving around in a go-kart
Old Mar 10, 2010 | 03:22 PM
branman1's Avatar
branman1
They come with replacement rear bump stops.
Old Mar 10, 2010 | 08:07 PM
Blair's Avatar
Blair
Mine came with the same rear bumpstops, plus ones for the front. They are worth their weight in gold...
