tuning $$$
I have read alot of posts w the pros and cons of tuning, is a $350 tuner gonna make a difference in my 06 GT? only have a CAI and flowmasters. not gonna put a supercharger on it so what can I expect form HP and torque gains from factory? what about shift points?
Tom
Tom
I definitely can feel the difference between stock and tuned. Shift points are a lot sharper and improved. Since you have a CAI already, the tuner will really help you get the full power from it. The only real con I can think of is I that step on it a lot more = poor mpg
If money is the issue, look around on the classified section or CL/ebay for a used tuner that is unlocked
What brand cai do you have already? When I bought the car it had an Airaid intake with no tune, and it was not much different than stock as far as I could tell.
I would look at the classifieds and pick up a used intake then add the tune. I picked up a lightly used steeda intake and an sct x3 for $385. Then another $99 for 3 tunes from brenspeed. HUGE improvement over stock.
Your CAI isn't doing squat w/o a tune. A good Tune (Brenspeed, AM/BAMA, Tillman) with that CAI will net you about 15-25 RWHP or more over stock. The mufflers don't add any performance.
And I agree with the above statement that even the 87 octane custom tune kicks azz over the stock 87 tune. And it gets incrementally better as you go up in octane.
Ok so several options on the tuner. so what exactly does the tuner do to the computer? can it be reversed? will the gas milage suffer? sounds so simple cannot understand why it costs so much. can I use the tuner on another Gt? my only experience is with a diesel truck and a bullydog and wow what a diffference. personally I don't like the throttle lag......with a fly by wire system I am waiting for the toyota throttle problem to happen. I would also like to change the shift points. any help would be great. Thanks
Tom
Tom
