H Pipe HELP!!!!!
Old Mar 14, 2010 | 05:59 PM
NOLA26's Avatar
NOLA26
Default H Pipe HELP!!!!!
I am in the middle of installing my Pypes O/R H pipe. First I noticed thay my stock pipe is in one piece down the driver and passanger side. My Pypes version is in two pieces (not including the H part that is not assembled). Also the stocker has no hangers attached to it and the Pypes one has a hanger on both sides. Did Brenspeed send me the worng part? Here is the part I ordered: http://www.brenspeed.com/hfm23.html
I noticed that the header description says 05-07 GT but the info says 05-09 GT. So what is it?? Should I put the stockers back on or what? Here is a pic of the Pypes from Brenspeed:
Old Mar 14, 2010 | 06:05 PM
loudnlow's Avatar
loudnlow
You have the correct part don't worry. The pypes h is 4 pieces and has hangers on it
Old Mar 14, 2010 | 06:06 PM
NOLA26's Avatar
NOLA26
Ok so do I just not use the hangers? Or cut them off cause my stock h does not have anything?
howarmat's Avatar
howarmat
s197 Junkie
look at tacobills install....it was the older 1 piece install but you can see the stocker removed there. and i assure you it has hangers.
Old Mar 14, 2010 | 06:16 PM
NOLA26's Avatar
NOLA26
I know his does but I was under my car and I ran my hand all over the pipe down to the H and I do not have any hangers? Is the 09 different?
Old Mar 14, 2010 | 06:22 PM
one eyed willy's Avatar
one eyed willy
if your 09 does not have hangers then there wont be anything in the way of the hangers on the pypes .so the pypes hangers will just float in the air,should not effect the install....i find it hard to beleive there are no hangers though??
howarmat's Avatar
howarmat
s197 Junkie
there has to be. otherwise there in no support for the exhaust from where it bolts on to the stock manifolds all the way to the hanger on the mufflers and that would be it. check the transmission for the crossmember that the hangers attach too
Old Mar 14, 2010 | 06:27 PM
NOLA26's Avatar
NOLA26
I will post the pics when I finally get the stockers off, might have to wait a few days though. Having a problem breaking the bolts to the headers. I gonna have to wait till I can get to the lift at work.
Old Mar 14, 2010 | 06:29 PM
howarmat's Avatar
howarmat
s197 Junkie
just spray with PB blast/wd40, they will come loose after a 20 minute soak
Old Mar 14, 2010 | 06:34 PM
loudnlow's Avatar
loudnlow
Yeah mine were hard until I used wd40 then they broke loose easily
