$6500 to spend to rebuilt motor - How would you do it?
So it looks like the dealership, in lieu of my email to the owner/gm, might be stepping up and cutting me a check on Monday. If I add in there a little of my funds, I figure I'd start with a $6500 figure to rebuild the engine+ some. So, how would you do it? Keep in mind I/my dad/my friends would be doing the work. Lets also assume the heads are still good for now . . .
I was thinking B302 shortblock + stage 3 Saleen upgrade. I had thought about doing cams, but with the forged shortblock I should be able to do enough boost to get to the power levels I want, and I could take the money saved on cams and get the dual fuel pump setup.
*mods are welcome to change 'rebuilt' to 'rebuild' in the title.
You have alot of options. I can tell you I did mine for $3200 using all new shortblock parts. This includes all gaskets, fasteners, seals, fluids, machining, etc. The thread is in my sig if you want to get a good idea of what's involved.
The easiest would be to buy an aluminator for $3200 shipped. Head gaskets, bolts, other gaskets, seals, etc will run you about $400. You could make alot of power with that block if you wanted to. I'd stay with the stock bore and stroke.
Let us know what you decide.
I'm not saying the Brenspeed block would be bad but if I was choosing a shortblock it would be the aluminator.
If I was having someone build it I think I'd contact HMS. That's just based on gut feel from some of the input Chris Haney has given on this forum. His website also shows the equipment and processes he uses when machining a block.
