Tube in the trunk?
Has anyone put a bass tube in the trunk of their 2010?
In the past, I have put an amplified bass tube in the trunk of my cars -- simply splicing off of one of the rear speakers. I then turn the 'gain' up on the tube so that the car is thumping as high as I could want it when the stock radio's bass adjustment is only half way.
In that manner, the bass can then be turned way down most of the time, putting only mids and highs through the other speakers while getting good bass response from the trunk.
It won't win awards, but it's very functional and cost effective.
Problem here, I don't see a great place in the trunk to mount it, given the spare tire cover takes up most of the room. Has anyone mounted a tube in the trunk? Also, where did you pull power from for the amp?
Take a look at the JL Audio Stealthbox that is made for the 2010 Mustang.
There isn't one. You would have to tap into the existing speakers with a hi-low line out converter. This is the one I am currently using on my 2010 GT with the JL Audio Stealthbox and JL Audio 500v1/2 amp: http://www.crutchfield.com/p_142SLC4/Scosche-SLC4.html
The only place in the '10 I can think of to put a tube so it looks at least somewhat decent/ out of the way is sideways right behind the seats after that little hump. I'd even carpet it probably. As far as the sub out I have no idea how the shakers work (I assume thats what you have?)
