My Long Awaited Build Take TWO!!! Doing it right the second time.
Old May 2, 2010 | 05:53 PM
Boozshey's Avatar
Boozshey
Default My Long Awaited Build Take TWO!!! Doing it right the second time.
So as most know a clogged cat caused my motor to give out. So in light of having to rebuild it's going to have a built bottom end now.
(List of new parts... Not including all the other stuff I already have)
Engine
4.6L Iron Block
Kellog Cobra Crank
Scat Rods
JE Pistons 8.8:1
ARP fasteners
GT500 Oil Pump, TSS Gears o-ring mod...
Valve Train
Stage 2 Ported Heads
Comp Springs
(After everything is running good)
Comp 127550 Cams
Phase Limiters
Transmission
Spec Aluminum 8 Bolt Flywheel
Spec Stage 3+ Clutch
Wheels/Tires
Jeg Star Wheels:
15x11 Rears
15x4 Fronts
M/T ET Streets 26x15x11
Skinny fronts...
Misc...
AFCO Radiator
Slim Line Fans
Mishimoto Hoses
Pi-Thon Hose Clamps
AVIC x920BT Stereo
Polished all steel hoses, A/C Lines and Alternator
Gutted-Cats with H-pipe
Old May 2, 2010 | 06:03 PM
marcuskeeler's Avatar
marcuskeeler
Good luck with it mate, looking forward to following your progress.....
What are you doing suspension-wise to compensate for the iron block?
Old May 2, 2010 | 06:26 PM
hammeron's Avatar
hammeron
looking good booz, keep the pics coming.
Old May 2, 2010 | 06:33 PM
Tylus's Avatar
Tylus
looks nice. between the 2 build-ups you are going to have one mean *** car
Old May 2, 2010 | 08:11 PM
opiwan's Avatar
opiwan
Looking forward to seeing this new build!
Old May 2, 2010 | 08:14 PM
candymanjl's Avatar
candymanjl
Good luck man! It's gonna be sick
Old May 2, 2010 | 08:35 PM
dstang10's Avatar
dstang10
Should make some serious power now......what HP level are you looking at hitting
Old May 2, 2010 | 08:37 PM
Boozshey's Avatar
Boozshey
600's.... Looking to get the car into the 10's.
Old May 2, 2010 | 08:40 PM
Ford_Dude's Avatar
Ford_Dude
Cool
are you in a Smog controled area?
if not maybe go no cats?
I look forward to seeing this
Old May 2, 2010 | 08:43 PM
Boozshey's Avatar
Boozshey
No sort of inspection in Florida. But I am military so who knows where I might end up next. Also, gutted cats essentially are the same as no cats...
