Car shut off
Old May 3, 2010 | 09:06 AM
mcstang's Avatar
mcstang
Default Car shut off
I was driving down the highway and when I went to cross over traffic to turn, my car shut off. That could have been bad news. What could have caused that?
06 GT Auto
Running "Street" (Bama Torque Tune)
No Error Codes
Car started back up and then was running fine.
Any help would be appreciated. Thanks!
Old May 3, 2010 | 11:10 AM
ski's Avatar
ski
2 possible causes are a dirty MAF sensor and/or a dirty throttle body.
Old May 3, 2010 | 12:31 PM
MoneyShot's Avatar
MoneyShot
has your car been leak proofed? water on the sjb might have done this.
Old May 3, 2010 | 01:42 PM
mcstang's Avatar
mcstang
Default leak proofed
No...is that covered under warrantee?
Old May 3, 2010 | 01:44 PM
mcstang's Avatar
mcstang
Default dirty
You calling my car dirty? I'm a retard when it comes to fixing cars. Is there a quick fix?
Old May 4, 2010 | 10:42 AM
ski's Avatar
ski
If you installed your aftermarket CAI, then you should not have any problem uninstalling, cleaning, and reinstalling the MAF sensor and TB. A special aerosol cleaning spray is available for each at most auto parts stores.
Old May 4, 2010 | 10:47 AM
JCON's Avatar
JCON
I have had my car shut off twice on the highway in the last two months. my MAF, filter, and TB are clean. Happens when I coast down a large bridge in neutral (as soon as I go in to neutral) Any ideas?
Old May 4, 2010 | 01:44 PM
MEK's Avatar
MEK
I don't know what year the poster has, but I thought I remembered a TSB for this issue on earlier model S197's? Something to do with the fuel pump? I don't remember exactly, but if you search the subject, you should be able to find it. I had mine shut off shortly after I had changed the air filter, I used a Fram, which I will never do again. A "sliver" of filter media from what looked to be trimming during manufacture, had come loose and lodged in my MAF sensor? After having it towed and several hours at the dealer, the mechanic pulled the MAF sensor and showed me the "sliver" wedged in it. No more Fram anything for me.
Old May 4, 2010 | 04:14 PM
MEK's Avatar
MEK
Found the TSB, here is the link:
http://www.mustang2005.org/TSB/tsb06-9-9hesonaccel.pdf
I don't know if this is your problem, but I thought I would throw it out there. From the TSB:
"After coming to a stop from a highway type cruise, some vehicles may experience a hesitation when the customer begins to accelerate. Air bubbles can form around the fuel pump during a long cruise and be ingested into the pump on acceleration causing a hesitation."
Old May 5, 2010 | 06:18 AM
mcstang's Avatar
mcstang
Default Thanks
I printed that out and will give it to Ford when I do my scheduled maintainance. I went ahead and called them and the service tech said that they have had to replace the MAF in a lot of these. He said do not try to clean a newer model MAF.
I also ordered a replacement C&L filter as they said it was recommended at my mileage and only $39.00. Decided not to mess with cleaning it at that price. They said people have had problems when they become too dirty.
KEM Motorworks
Aug 14, 2015 10:13 PM
drumhedd2005
Aug 13, 2015 09:59 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
dseg
AmericanMuscle.com
Aug 10, 2015 03:29 PM
