Sponsored by:
Sponsored by:
Best RPM to shift for 1/4 mile times?
Old 05-10-2010, 06:30 PM
90stang5.0
90stang5.0's Avatar
Default Best RPM to shift for 1/4 mile times?
My 05 has 3.55 gears, 5 speed, JLT CAI, 93 octane Brenspeed tune, UDP's and some suspension mods. The original max HP RPM was 5750 and before the tune, it really didn't want to rev above that. But now it will easily rev above 6k. I do not go to the track very often, but wanted to know what shift RPM will achieve the best 1/4 mile times? Ed
90stang5.0 is offline
Old 05-10-2010, 07:21 PM
candymanjl
candymanjl's Avatar
redline is 6000 rpm and that's where I shifted at the track. on my car I was trapping in 3rd when it was bone stock. typically shifting at peak HP is your best bet and these cars make peak HP at redline especially after some mods.
candymanjl is offline
Old 05-10-2010, 07:23 PM
replica
replica's Avatar
Just before fuel cut. Shifting out at max power will probably make you slower because you fall even further out of the powerband.
replica is offline
Old 05-11-2010, 04:35 PM
90stang5.0
90stang5.0's Avatar
Thanks.
Old 05-11-2010, 05:02 PM
jayed53
jayed53's Avatar
Isn't shifting at 6k rpm really bad for the engine? Im just guessing here, but I could be wrong.
jayed53 is offline
Old 05-11-2010, 05:04 PM
Lupo222
Lupo222's Avatar
Location: Camp Lejeune, North Carolina and Fort Lauderdale, Florida
Why would it be? I mean, its not good to do it everytime you drive, but as long as you don't bounce it off the rev limiter every time, you should be ok.
Lupo222 is offline
Old 05-11-2010, 05:05 PM
gman73
gman73's Avatar
Shifting at 6K or above once in a while shouldn't hurt the engine. You want to shift above your peak hp so in the next gear you will be close to the peak of the power band.
gman73 is offline
Old 05-11-2010, 10:03 PM
candymanjl
candymanjl's Avatar
it's only bad if that's how you drive 24/7. anything done to an extreme is bad, in moderation like an occasional trip to the track or romp on a freeway on ramp and you're fine.
Old 05-11-2010, 10:21 PM
robs
robs's Avatar
Drive it like you stole it!
I WOT/Red Line shift at least 2 to 3 times a day!
robs is offline
Old 05-12-2010, 12:43 AM
Simon1
Simon1's Avatar
Whatever tuner you have go into it and turn all the RPM limits to 6800. Shift at around 640o. These cars like to rev and you will get better ETs and trap with a some extra RPMS.
Simon1 is offline
Quick Reply: Best RPM to shift for 1/4 mile times?
