replacing the air filter
Old May 14, 2010 | 01:23 PM
luis05gt's Avatar
luis05gt
Default replacing the air filter
can i drop a k&N cone filter like this one on the stock intake tube i need to replace my filter but am not ready to get a cai
http://www.autozone.com/autozone/cat...&parentId=42-0
my friend did it to his 04 but am wondering if i can do it to my 05
Old May 14, 2010 | 01:30 PM
replica's Avatar
replica
Not from what I remember. The box isn't a tube inside. Just a panel area.
Old May 14, 2010 | 01:34 PM
luis05gt's Avatar
luis05gt
i mean remove the box then attach a cone filter to it. when you remove the box it looks like you can add a cone filter then tighten the strap
Old May 14, 2010 | 01:36 PM
replica's Avatar
replica
I guess you could. Not sure why you'd want to do that though.
howarmat's Avatar
howarmat
s197 Junkie
no you cant....
Old May 14, 2010 | 01:41 PM
luis05gt's Avatar
luis05gt
the only reason i wanted to see if i could is cause my air filter looks really bad and i was gonna replace it with a regular k&n drop in but i saw that cone at autozone and remembered my friend was running a cone on his stock intake but his was a 04 whats the diffrence between mine and his since i cant do it
Old May 14, 2010 | 02:23 PM
Ford_Dude's Avatar
Ford_Dude
Just get a drop in filter from GreenFilters USA (much better than K&N) (and you can pretend like your going green)
(their thing is Green by way of less air restriction, and less trash to throw away)
Old May 14, 2010 | 03:03 PM
Nuke's Avatar
Nuke
Don't waste your money. Doing it as you described will cause you to run lean and throw a CEL unless the cone filter doesn't flow any more than the stock air box does. And if the later is the case, you won't gain a thing. Secondly, even a no-tune-required stand alone CAI made for your car will only gain you 3-5 RWHP whereas a good CAI & custom tune will gain you 20-25 RWHP or more.
Drop-in air filters don't do squat either.
Do it right the first time. CAI & tune.
Old May 14, 2010 | 07:10 PM
07blkgt62's Avatar
07blkgt62
+1 on a good CAI and custom tune, anything else is a waste of money.
Old May 14, 2010 | 09:37 PM
alkemist's Avatar
alkemist
+2 on good CAI and custom tune.
ShaneB26154
35
Mar 4, 2021 04:05 AM
Calizic
Aug 28, 2015 01:46 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
mweiland
Aug 13, 2015 05:11 PM
