Irregular Oil Reading?
So today i changed the oil in my 05 v6, i removed the plug drained the oil, i then put the plug back in and went to add the new oil. The v6 is supposed to take five quarts but i put each quart in then let it sit measured the level and added more if need be so i would not overfill. Once the levels checked out i decided to drive home from my grandparents (where oil change was done) its only about a five minute drive, if that. On the way the car starts to accelerate irregularly so as soon as i make it home i check under to see if there are any leaks which i found none, i then check the oil level with the dipstick and its reading way above the max? I decide to let it sit for about half an hour and check it again and still it reads way above. I then drain some oil from the pan let it sit and check the level again, yet it still reads the same level way above the max? i have no clue whats going on. any info is appreciated
First, did you change the filter? The filter holds maybe 1/4 quart or so of oil. Also, was the car level? And did you allow plenty of time for the old oil to drain? I usually wait until it hardly drips any more which could take about 15-30 minutes, depending on temperature. Other than those, there's no reason why 5 quarts would overfill a V6 4.0L.
Some guy on a Toyota forum did an oil change, or so he thought, and ended up adding motor oil to his tranny fill tube. Are you sure you're checking the right dipstick? (I'm sure you are. Just had to throw that out there...)
no i did not change the oil filter, i change it every other oil change so i just dropped the old oil, this is why i was adding a quart at a time knowing the filter holds some oil and ya the oil was dripping for a good while i even had something to eat while i was letting it drain, so it was a good twenty minutes. I have followed this same procedure in the past and the car has ran great. I am now stuck because i let some of the oil drain but with these irregular readings i dont know if i now need oil or am still above the max?
update: after letting the car sit almost all day the fluid level for the oil checks out i dont know wat was going on with that i guess it needed extra long to settle. But as far as the odd acceleration problems i believe it is the transmission pan it seems to have a slow leak there is some condensation on the bottom of the pan near the plug, im having it checked it out tommorrow.....i think it was just my luck that all these things happened at the same time leading me in all these different directions lol
Well, if you didn't replace the filter, that's obviously why it's overfull. It doesnt matter how long you let it drain, the oil in the filter stays there. They can hold nearly half a quart...
Do it right if you're going to do it. Replace the filter every time
I kink of agree but will go one step further and say change both as it's cheap cheap cheap. My change costs 112.00 and for piece of mind that's cheap
Sorry. Off-topic.
