Oil catch can
Where are you guys mounting these and where/how are you running the lines to? I did a search and found some mounting pics, but none really of which side you run the line to, and the fittings you used.
My dad has offered up his catch can he was going to use on his 335i because we ended up my car project first (mainly because my motor went BOOM).
I mounted mine on the Whipple heat shield. The line runs from the driver side valve cover to the catch can inlet then from the catch can outlet to the throttle body. I used a moroso catch can and AN fittings from summit.
Here is the JLT with my Whipple. Easy access to remove as well.
http://www.modularfords.com/forums/s...or-and-Whipple
