Gauge Questions
I've recently finished installing my Autometer Nexus gauges (Fuel Pres, Boost/Vac, Water temp), and I've been left with a few questions.
1) The fuel pressure reads 27/28 at idle. Shouldn't it be at 39 psi?
2) Typicaly, when you turn on the gauges and start the car, the boost/vac gauge reads proper vac just like it should, then when you turn the car off it reads 0 psi, like it should. The gauge seems to work perfectly most of the time, BUT, when you put the key in and turn the ignition on immediately, the boost/vac gauge reads almost double, sitting at 0psi at idle, then (roughly) 11psi when you turn the car off. What would be causing this? I would think its wired to the key-hot wrong, but the fuel pressure gauge (only other gauge hooked up right now) is totally unaffected.
I have the gauges wired to turn on/off with the radio, not sure if that has anything to do with it.
3) Where/how do I install the water temp sensor? I've looked around but couldn't find much info on where to install the sensor on out cars. A little guidance would be greatly appreciated =)
It sounds to me like you picked a bad voltage source for your gauges. I wired mine with a vampire fuse into the passenger side kick panel fuse box. Find a fuse that is keyed power source and tap in. I'll try to find my gauge install thread from a few years back, but bear with me because it's hard to find threads from before mustangforums was overhauled.
Thanks for the input. I try that when I get a chance to work on it. If I would have wired it there to begin with, but I didn't worry too much about it since it has a separate constant power source (thats wired to the battery).
from another thread somewhere on the forum , there is a port for the water temp sensor on the left hand side of the block by the exhaust header
i tried to remove it, but the bastard in there was stuck good and didn't want to come out
i just bought a water temp hose adapter from autometer and cut the upper rad hose and stuck it there
