Gauge Questions
Old May 27, 2010 | 10:49 PM
doode's Avatar
doode
Originally Posted by Fresh_GT
Thats what I was thinking about doing, but was wondering if there was another way that was easier or worked better. I thought I read that mounting it there causes a delay until the engine warms. Is this the one you got http://www.autometer.com/cat_accesso...il.aspx?vid=52?
that's the adapter
as for the delay, yes...the gauge won't read anything until the thermostat starts opening up
i mounted it in the upper hose as it measures coolant leaving the block, usually reading around 80 degrees Celsius
Old May 28, 2010 | 09:16 AM
Fresh_GT's Avatar
Fresh_GT
Thanks a ton for the advise. Hopefully I can get my car in the newly remodeled garage for some more wiring fun.
By chance, do you think I could find this adapter, or and equivalent, locally to save on shipping?
Old May 28, 2010 | 03:57 PM
Fresh_GT's Avatar
Fresh_GT
Well, I took your advice and rewired the key-hot for the gauges to a fuse in the passenger side kick panel (fuse 13 to be exact - fuse panel diagram) and that took car of that annoying false reading. Thanks a lot.
Old May 29, 2010 | 12:05 AM
doode's Avatar
doode
i got mine from a local parts store
damn expensive....$58 cad
don't forget the $1.99 teflon tape from the hardware store !
Old May 29, 2010 | 09:27 AM
157dB's Avatar
157dB
Cut & Paste Expert
Dats what we here fo...
Old May 29, 2010 | 10:18 PM
Diabolical!'s Avatar
Diabolical!
Glad you got it worked out.
SteelerNation82
Sep 16, 2015 07:11 AM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
