26x11.5x17 drag radial
They look like they fit fine. If you are just going to use them for the track, they will be fine. In fact I should have got them instead of the M&H 275/50/17 as these tires are a little too tall.
Are you talking about the Mickey Thompson ET Streets that are bias ply tires and not radials? Their measurements are 26x11.5x17. Drag radials are usually measured something like 275/50/17.
If you are talking about the ET Streets, then they are not 11.5" wide, for some reason they measure the DOT ET Streets differently. Their treadwidth is actually 9.5" wide. I have these tires on stock 17x8" wheels for the track, they fit fine.
.....NT-555R BTW
As far as hooking, they made my car wheelhop badly when I went to the track so idk that much. They did pretty well on the street though and the shorter sidewall(shorter gearing) was noticible and made the car more fun.
IMO the tires look too small on the car, height-wise
