Battery drain...
Old Jun 1, 2010 | 06:25 PM
siberian.mist's Avatar
siberian.mist
i bet its the alternator
Old Jun 1, 2010 | 09:33 PM
mdg's Avatar
mdg
Went to Autozone and they did a load test of the battery and alternator, turns out the battery was bad. Purchased a new one and it starts like a champ. Will be returning my 3 month old battery to NTB next weekend. Glad it wasn't the alternator. I appreciate all the feedback.
Old Jun 2, 2010 | 07:13 AM
Nuke's Avatar
Nuke
I'd still be a little suspicious. Unless the battery was defective to begin with, your problem should be resolved. But there's still the possibility that the alternator is causing the battery issue. I'll assume that the load test on tha alternator was fine since you stated they tested that, too. But I'd keep a watchful eye on the battery over the next few months. You may want to check the terminal voltage every few days after the car has sat overnite and before starting it just for a little peace-of-mind.
Old Jun 2, 2010 | 07:17 AM
mdg's Avatar
mdg
yeah, I'll definitely keep an eye on it, thanks.
Old Jun 2, 2010 | 07:33 AM
Nuke's Avatar
Nuke
I probably should have added that you should see typical no-load voltage of about 12.6 volts or higher and it shouldn't trend down much if any over those first few months. There will be some variance (temperature, amount of previous charge, etc) but you should be able to get an idea of what's normal and what's not over time.
Old Jun 2, 2010 | 07:56 AM
Norm Peterson's Avatar
Norm Peterson
Originally Posted by Nuke
The Shaker 500 AND 1000 have the same power draw issue.
I Bing-searched on "Shaker 500 battery draw" and got directed back to an old thread here on MF. Apparently there is some correlation between leaving CDs in the changer and battery draw. Leave CDs in, draw more current. Quite a bit more, if you go into the entire thread.
https://mustangforums.com/forum/4329128-post81.html
I have the 500, never leave any CDs in it except during rest/food stops on a long trip, almost never shut it off, and have never had a starting problem even after three weeks not starting the car.
(Nuke - does MS ('10) = Grand Gulf?)
Norm
Old Jun 2, 2010 | 08:17 AM
Nuke's Avatar
Nuke
Great find, Norm (and btw, PM sent).
I keep CD's in my Shaker 500 and the car often sits for 1-3 weeks at a time. So far so good. Maybe I have one of the batteries from a better lot.
Old Jun 2, 2010 | 08:47 AM
Norm Peterson
I'd be at greater risk of getting lazy and leaving CD's in the box if I still had that 55 mile commute (ref. PM). But for my now 5 mile commute (up from 4) it just isn't worth the trouble, and there's a segment on one of the broadcast FM stations that comes on during that little slice of morning travel time that I kind of look forward to anyway.
Norm
Old Jun 2, 2010 | 08:53 AM
replica's Avatar
replica
Glad I have a base GT. My stereo is terrible, but it's better than those MASSIVE speaker grills in the door and a third of the trunk occupied by what looks like an outdoor deck speaker disguised as a rock.
Old Jun 2, 2010 | 09:36 AM
Norm Peterson
That's only the 1000. No big boxes in my car's trunk with the 500. Door speaker size is a judgement call.
Norm
