Air Filter vs CAI
Oh yeah, not sure if the drop in KN is oiled gauze but if it is DON'T swap your cellulose paper air filter for it. That would probably be the worst thing you could do for your new car. The cellulose paper filters much, much better. Not worth the 2hp!
If your heart is set on a filter swap, look for a synthetic, dry filter drop in like Amsoil etc.
The Meter on these cars is a slot meter. When you install an aftermarket CAI most make the tube where the meter slots in larger. If you dont reprogram the car thinks their is less air going through the tube than their is for a given velocity. A lot of the gains come from making this tube larger.
The throttle opening rate is limited on these cars. They also close the throttle on powershifts, their is also a perceptable lag waiting for it to reopen. They also need the limiter raised at least 500 rpm for best performance. A Tune fixes all of this.
A JLTII CAI / Mailorder SCT Tune Combo from BamaChips helped my car over 4/10 and 4 mph in the 1/4 mile. They can be worth even more on the automatics witht he revised shift firmness, shift points and converter lockup.
Overall the much better response with a tune makes the car feel much more like an old 60's Muscle Car.
Well, many tests with oil analysis from labs confirmed that "sometimes", not always, an oiled filter did flow better, but allowed more dirt (silicon) to get through. This will show an increase in silicon in the test results. When I bought my C&L it had a K&N cone type filter so I was forced to use it. If I see elevated silicon level in my oil analysis I will be changing to a dry type cone filter.
not true. I run K&N's in my every day drivers for .. oh.. about 15 years now and you can lick the intake tube after the filters. They do not let any dirt/dust by any more then a paper filter. its simply not true.
IMO, a well maintained K&N will perform better than a paper element, but some people don't know how to properly care for them.
