highest mph 1st can do?
Old Jun 7, 2010 | 01:39 PM
raywang5's Avatar
raywang5
Default highest mph 1st can do?
i would like to know what the highest rpm a supercharged mustang GT can go in 1st gear. 36mph? is is possible to reach 60 in 1st gear?
Old Jun 7, 2010 | 01:57 PM
Torch Red GT's Avatar
Torch Red GT
No and why would you want to reach 60 in first gear?
Old Jun 7, 2010 | 02:18 PM
siggyfreud's Avatar
siggyfreud
Depends on the transmission and the rear end. And no, unless you have extremely low (numerically) gears, you'll never see 60 in 1st.
Old Jun 7, 2010 | 02:19 PM
mstngsule68's Avatar
mstngsule68
i could see someone puttin it in 3rd thinkin it was first? idk... only thing i got
Old Jun 7, 2010 | 02:39 PM
jahudso2's Avatar
jahudso2
My car will do 40 mph in first gear. In order to hit 60, you would need a lower rear end ratio than 3.31 and really tall tires. Your acceleration would be terrible unless you had a ton of power. I assume this question arises from seeing the z06 vettes and such do 60 mph in first gear. Most cars with 0-60 times under 4 seconds all do 60 mph in first b/c the 1-2 shift adds a good half second.
Old Jun 7, 2010 | 02:45 PM
raywang5's Avatar
raywang5
thats what i mean. lol..
Old Jun 7, 2010 | 02:48 PM
GTjoe49's Avatar
GTjoe49
Top speed in any given gear is a factor of max engine rpm, gear ratio in transmission, rear end ratio and rear wheel diameter (excluding factors such as slippage and wind resistance).
Supercharging, hp, turbo...etc will only effect how soon you get there.
Road & Track data has the 2010 Mustang GT with 5sp man and 3.73 rear topping out at 41mph in 1st gear at 6500rpm in 2.7 seconds.
Old Jun 7, 2010 | 02:54 PM
2005Redfire6's Avatar
2005Redfire6
I can only go about 30 .
Old Jun 7, 2010 | 03:32 PM
Nuke's Avatar
Nuke
+1 on a function of tranny, gears, rev limit and tire OD.
With my setup, my top speed calculates at 41.31 MPH at the factory rev limit and 42.97 at my rev limit of 6500.
Old Jun 7, 2010 | 05:26 PM
Unleashedbeast's Avatar
Unleashedbeast
All numbers are assuming rev limiter @ 6500 RPM, the factory 27.3" tire (235/50/18), and 1st gear of a manual T3650 (3.37 ratio)
3.31 rear gears - 47.35 MPH
3.55 rear gears - 44.14 MPH
3.73 rear gears - 42.01 MPH
4.10 rear gears - 38.22 MPH
You will NEVER see 60 MPH in first gear without hitting the rev limiter first, or destroying your engine. You would require a rear gear ratio of 2.61 before you could hit 60 MPH in 1st gear.
