Steeda C.A.I. Help needed.
Old Jun 9, 2010 | 08:19 PM
bullitt ben's Avatar
bullitt ben
Default Steeda C.A.I. Help needed.
Just purchased a Steeda C.A.I. on Ebay,
I installed it, programmed the car with my SCT
punching in STEEDA C.A.I. ,started the car and it did not run well.
I noticed in the SCT programming options for C.A.I.'s it is written ''Steeda 90mm''
I measured mine and got 87mm inside diameter
Does Steeda make two different size Maf housings?
I need to know cause i ordered a custom tune from brenspeed and i may need to contact them so they can adjust their parameters.
Old Jun 9, 2010 | 08:29 PM
SirKnightTG's Avatar
SirKnightTG
I had no idea Steeda made an 87 mm version. And yes it does matter as far as tuning goes.
I have a Steeda and I always assumed it was 90mm. I never had tune problems so I should be ok I think.
Old Jun 10, 2010 | 07:13 AM
Nuke's Avatar
Nuke
Define "...did not run well".
I suspect that you measured incorrectly and that you need to disconnect the battery for 20-30 minutes and then put a good 20-40 miles of some aggressive driving on the car. It may take a day or 2 of this style driving for things to settle down.
Also, if you're using the canned SCT tunes then I'd definately dump them and get tunes from Brenspeed or Doug at AM.
Old Jun 10, 2010 | 11:31 AM
bullitt ben
currently in contact with Dave over at brenspeed waiting for some info but he confirmed Steeda DID make two size C.A.I's
really wish i can get this issue solved .
Old Jun 10, 2010 | 11:34 AM
Nuke's Avatar
Nuke
Brenspeed should have no problem writing you appropriate tunes for the different size.
Old Jun 10, 2010 | 11:52 AM
Salas's Avatar
Salas
Steeda made two sizes. The newer one is the 90mm. However, I believe the old one was 85mm, not 87mm.
Old Jun 10, 2010 | 12:31 PM
SteedaGus's Avatar
SteedaGus
Former Sponsor
That is correct, our early units manufactured in 05 and 06 are smaller. Units made in May of 06 all the way through to today they have been 90mm.
Old Jun 10, 2010 | 03:30 PM
bullitt ben
I measured maf housing INSIDE diameter at exit side (where it attaches to elbow)and got 87mm ?????
Old Jun 10, 2010 | 03:55 PM
kevinmalec's Avatar
kevinmalec
Dave at Brenspeed should be able to create a new tune and email it to ya!
He's a great guy to work with. =-)
Good luck!
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
UrS4
Sep 30, 2015 10:13 AM
mungodrums
Sep 28, 2015 10:54 PM
Sep 24, 2015 09:18 PM
