SHR Honeycomb panel installation
Old Jun 19, 2010 | 10:34 AM
incorrigible's Avatar
incorrigible
It's most likely off due to the positioning (or more accurately, mis-positioning) of the faux gas cap. I'm sure this part is subject to some positional tolerances making it off from it true ideal location which is causing the panel misalignment.
Pics?
Old Jun 19, 2010 | 12:02 PM
TPony's Avatar
TPony
1MM of extra space? Hmmm..still within government specs...so, I say you are good to go...
Old Jun 19, 2010 | 03:07 PM
157dB's Avatar
157dB
Cut & Paste Expert
Yep, the faux cap is the problem with the install being partially off.
Its rarely centered as the alignment pins dont fit the alignment holes
in the panel tight. The holes are sloppy allowing for a slight
mis-alignment of the faux cap from the factory.
I did a honeycomb first but didnt like it cus of the fit and quality.
I went with the CDC ribbed panel for a more distinctive look.
I also used 3m 4298 adhesion promoter...
Attached Thumbnails SHR Honeycomb panel installation-rearviewlowered.jpg   SHR Honeycomb panel installation-cdc.jpg   SHR Honeycomb panel installation-4298adhesionpromoter.jpg
Old Jun 19, 2010 | 06:31 PM
VictoriaRR's Avatar
VictoriaRR
Pics?
That's an interesting suggestion I hadn't considered.
I'll try and snap a couple pics before we head out for my niece's recital. I should be able to get them posted late tonight or tomorrow sometime. I was waiting until I got the tail light bezels on, but it wouldn't be bad to have a few comparison pics for down the road.
Old Jun 19, 2010 | 07:17 PM
Grabborange's Avatar
Grabborange
My SHR panel is in transit right now to me. I have gloss black vinyl in the rear right now, but like the look of the panel better. When you first apply it using the adhesion promoter are you able to move it around a bit to get in the right position?
Old Jun 20, 2010 | 02:12 AM
VictoriaRR's Avatar
VictoriaRR
NO. That is one thing I'd advise you to be careful with. Once it's down... it's pretty much down for good. We tried fitting it before removing the adhesive covering to see how we were going to position it. Then we removed it to make it stick. The instructions say to flex the panel so that you can put the center against the trunk first and work your way outward. The panel is very sturdy and hard to flex, so this is nearly impossible unless you're The Hulk. As such, we got it down, weren't totally satisfied with the placement, so we were able to pry off the right side. The left side practically wouldn't budge, though. So be very very careful and make sure you have it how you want it before you press down because you probably will not get a second chance.
mtgldr
Feb 3, 2024 09:00 PM
copestang
Oct 11, 2015 07:17 AM
Gkid182
Sep 22, 2015 08:17 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
