Gas Pedal Delay
I own an Automatic V6. The gas petal delay is a PITA! I always back into my garage from the street. It always hesitates after you put it in reverse which drives me nuts. Plus it always does it when you go around a corner and then step on the gas again, kinda like it misses for a second. Just that slight delay in response pisses me off. My driveway had a pretty good slope on it down to the street. If I have to go forward and stop and then put it in reverse to get in the garage (pretty tight fit) I literally roll forward a foot or two with the shifter is in reverse and foot on the gas until the computor tells the transmission to back up!
So I am still trying to grasp this tuner idea. I have seen them for sale but wouldnt spend the money on something I'm not quite sure of the purpose in getting. So right now I dont own any tuning device. I am not planning on doing any engine hop up work on the car. I just want it to drive correctly! So whats the first step to get this resolved? Am I going to need to buy one of those tuners and get a program for it? If you reflash the computor on the car does it wipe out the program thats installed if you had one installed? I ask this so if I have someone tune it for me in my local area and then say you change out the battery in a few years will the program be wiped out where you have to have it done again etc? TIA, Jim
ORIGINAL: Jim Smyth
The shop in my area that does custom tunes uses the SCT XCal, so when you get a tune from them, it includes the XCAL, the custom tune, and the dyno runs to get it tuned right. Once you have the XCAL (or a Predator unit), both the custom and the factory tunes remain stored on the programmer. You can switch back and forth for warranty work, or after a reflash.
~MO
ORIGINAL: JerryP
Where can this be done in Upstate NY, in the Rochester area? Thanks.
not to throw more options at you, but you could always go with a canned tune, say from brenspeed.com or similar, that's what i did, and i couldn't be happier.
my throttle response was a night and day difference after downloading the tune
ORIGINAL: Daniel60
In first gear when you press the gas pedal it hestitates for a moment and then fires away. I have the same problem. I wonder why Ford did not make this correction.
drive by wire is computerized...
your input to the computer via drive by wire is instaneous, (or close to it)
throttle response is NOT. The computer generally will not allow you to go WOT without some sort of gear in place, thats why the Predator and SCT can give you HP with just a tune.. they reduce/remove that little annoyance... among a variety of other things...
ORIGINAL: momustang
The delay is due to the '05s drive-by-wire system. On this model, there is no direct linkage between the accelerator pedal and the throttle. The computer detects the position of the pedal, then adjusts the throttle. This accounts for the delay, the torque limitations in 1st & 2nd gear, and the rev limiter.
~MO
~MO
ORIGINAL: greatgro
There shouldn't be a delay with drive-by-wire while accelerating. I know mine doesn't have one. Mine just delays when getting OFF the gas. That is normal and a product of drive-by-wire. It reduces emissions and increases fuel economy. But there shouldn't be hesitation or delay when accelerating. Drive-by-wire is computerized and instantaneous.
ORIGINAL: Daniel60
Programming-wise, it's just code that reads hundreds of variables at one time, such as the throttle input (from your accellerator pedal) and then calculates the estimated airflow required to maintain the air/fuel mixture, then estimates the resulting torque & HP from your pedal position, then adjusts everything (a/f mixture, firing, etc) accordingly.
Very simple.
Tuning will eliminate the problem.
~Mo
