Last edit by: IB Advertising
Browse all: Wheels and Tires
- Ford Mustang V6 1994 to 2004 Why is My Tire Pressure Light On?
Guide to diagnose trouble and recommended solutions.
Tire Pressure Light
Tire Pressure Light
Low tire pressure light continues to stay on even though theres plenty of air in the tires is there anything i can do? The wheels r the Shelby Alcoas 20x9 front 20x10 in the rear. The tires say do not exceed 50 lbs. I put 40 lbs in them cold.
I'd say check the TPMS sensors make sure one didn't come loose or something. I've also heard about them shifting on the rim before as well....that could be your problem.
I think your wheels and tires are bad. You should send them to me and I will dispose of them properly.
LOL i think I'll keep them for now.
Yes they have the sensors in them i do know that. Hoe can you check them to make sure they didnt shift or move?
https://mustangforums.com/forum/2005...ing-wheel.html
The thread itself deals with a different issue but look specifically at reply #24 and start reading from there. One member had issues TPMS sensors coming loose.
Hope that helps!
Try and find someone local to you with the tool. Takes like a minute to program them. American muscle sells the tool as well. Cheaper to buy it then paying the dealer if they are going to charge you. Just my .02
I was not aware....thanks for the info! I prefer not to be hitting the reset button all the time....this will save me a possible headache down the road!
OP.....sounds like that may be your problem. Did you have them recalibrated?
