why does my car do this?
Old Jul 13, 2010 | 03:29 PM
Mustang#5's Avatar
Mustang#5
What bugs me about mine, and I don't know if anybody had this problem. When I've been on the highway for awhile, then come off. I hit the throttle and it will hesitate then jump. This might happen once or twice on acceleration. But after that it's back to normal. I've reset the fly by wire system a few times. It seems to help but not always. Any ideas???
Old Jul 13, 2010 | 03:40 PM
nemosgt's Avatar
nemosgt
My '06 sometimes would start bucking as I pulled away. Happened only intermittently and when not fully up to temperature. My cure was to trade it in on a 2011. I'm not mechanically minded either.
Cheers.
Old Jul 13, 2010 | 03:44 PM
nemosgt's Avatar
nemosgt
Have you tried going back to stock tune and intake to see if it operates normally?
Cheers.
Old Jul 13, 2010 | 03:45 PM
Nuke's Avatar
Nuke
Usually, when the framitz bearings begin to fester, it'll cause the clausen tube to restrict resulting in a loss of freebit flow to the fresnel vomitz. Throttle puddling then results in submiffed speed manure. A complete injection system flux and rescan using a Diddle Box (available at most auto parts stores) will resolve your problem.
But if that's too much work, too, then a CAI & custom tune should do the trick.
Old Jul 13, 2010 | 03:48 PM
Nuke's Avatar
Nuke
And your problem is related to the fuel pump. Read the fuel pump related TSB's. Air bubbles will form in the pump during extended cruising (as little as 5 minutes of sustained speed). Attempting to accelerate results in hesitation as the air bubbles are forced thru the system. Once thru the car responds normally until the bubbles build up during another extended cruise.
Old Jul 13, 2010 | 03:52 PM
Goldenpony's Avatar
Goldenpony
Bingo! Give that man a cigar.
I had this same problem, as well as a funky fuel level sensor. I read up on the TSB, installed the new design fuel pump (pretty simple) and no more problems.
Old Jul 13, 2010 | 04:20 PM
2005Redfire6's Avatar
2005Redfire6
Originally Posted by Red Beast
im assuming its a manual? mine sometimes does it, or used to, my friends did as well, after you get better at shifting you wont really have the problem. but when it does it, depress the clutch again and repeat the normal process of starting, gas and release clutch and it should work.
if your not a manual then i have no idea what to tell you. i guess just follow what others say.
+1, feels like your on a pissed off bull.
Old Jul 13, 2010 | 04:32 PM
stang1012's Avatar
stang1012
Well put thats just what mine feels like, only more like a horse hahaha (I have a 6)
Mine is an automatic though. I just hope its not the start of somthing major.
Old Jul 14, 2010 | 06:42 AM
Mustang#5's Avatar
Mustang#5
Thank you for the true answer... I'll look at the tech bulletin. Makes sense I guess.
djbigskrilla
Sep 20, 2022 01:04 AM
chain
Aug 17, 2015 08:52 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
ccwebb
Aug 11, 2015 06:47 PM
