Miles per tank
Miles to empty is such a bullchit, useless, unreliable # that I can't believe people still use it. Since it's based on your prior average MPG's (which the on-board can't compute worth a crap) X the # of remaining gallons (which is another wild-azz-guess by the on-board), relying on it to tell you when you need gas is a crapshoot. And if your prior on-board data was based on one driving style such as granny and your current tank is based on driving like you stole it, you'll be scratching your nutz wondering why you're sitting on "E" in the middle of bumfuk.
I can get 26 MPG driving highway, pump-to-pump hand calculated. That would be 416 miles/tank if I was stupid enough to run it that low.
When you get to or below 1/2 tank, consider that it's time to fill up soon and be done with it.
I average around 280 miles per tank when I fill up, i typically get gas right before the light comes on and is usually about 14 gallons. On highway only drives I get about 400 miles on a tank!
A side note, sometimes when I'm driving it like I stole it and then fill up and drive easy without any resetting... it will tell me like 290 miles till empty, only to find out I drove 360 miles (the computer doesn't always update mid-drive.) So although not perfect, it works to an extent.
The only time that I bother with DTE is when I'm on a trip to/from my Dad's place. 325 miles is a long enough distance to set the beeper off a couple of times but is legitimately a one-tank trip.
Around town, I'll let it drop down below 1/4, and I'll have less than 200 miles in at that point.
Norm
Although some of the on-boards are accurate (my g/f's '06 Pony is typically within 0.2 MPG of the hand-calculated value), it seems that the vast majority are off to the conservative side by 1.5 to 2.0 MPG. My "gut" from the input on the forum over the past 3 years is that about 80% or more are inaccurate.
The difference in Miles to Empty is due to the onboard using the average MPG it computed previously x the "guesstimate" of fuel in the tank. Do yourselves a favor and don't even look at Miles to Empty (or whatever it's called).
TfcCDR
Sep 14, 2015 12:08 PM
