When I reloaded my Brenspeed tunes I first had to flash back to stock, then reload the 93 octane tune. I dont know if that is correct but when I tried to just reload the 93 it gave me an error, "no stock tune found" if I remember correctly.
Interesting, maybe because you tried to reload the same tune again. I just went from 89 to 91 without having to go stock first.
Originally Posted by Black GT
I don't know what kind of tuner he had, but I've reloaded the same tune several times without having to go back to stock on my XCAL-2.
Ditto
Originally Posted by 808muscle
Does reloading the custom tune really do anything? What about disconnecting the battery? Does that clear the computors driving habits curve?
Reloading the tune CAN help but disconnecting the battery for about 20 minutes or more will clear the adaptive learning. You don't need to reload the custom tune when you disconnect the battery. Just be aware that resetting the adaptive learning can sometimes cause some poor idle issues for the first 10-20 miles until the PCM has some data to settle it down.
Thanks for info guys. I just remember getting constant 21-22MPG after I installed tunes and now I am right at 19MPG. Maybe the hot weather has something to do with it. Im going on a trip tomorrow and after I get back I'll try to re-load the tunes again and see if it makes adifference.
Hell, I get 19.4 MPG with no mods, no tune. Though I do normally cruise on the highway for about 10 miles at 80mph. Other than that I just drive normally from red lights and never go WOT.
