uca help
Old Aug 15, 2010 | 07:25 AM
90stang5.0's Avatar
90stang5.0
Originally Posted by 07vbluestang
i added UMI lower control arms about a month ago but still had slight wheel hop. so today i add UMI relocation bolt in brackets, adjustable UCA and UCA bracket. i
Not trying to argue here, but he added the UMI upper mount, like I did, and the UMI website states the following:
"This mount also features a 14mm mounting hole for the upper control and corrects the clunking found with the factory upper control arm mount."
The upper mount should not be the problem.
Old Aug 15, 2010 | 11:53 AM
07vbluestang's Avatar
07vbluestang
it seems like the car is sitting higher than it was before. i can slide my floor jack under the rear to jack up under the pumpkin as where i could not before. it also seems like the axle is offset more to the drivers side. never noticed that before!! i think i am going to put jack stands under the car with the suspension unloaded, loosen all the bolts, load the suspension and add like #150 in the trunk then torque all the bolts. i know the hole in the uca is 14 mm. i checked it before i installed the uca.
mtgldr
Feb 3, 2024 09:00 PM
UrS4
Oct 3, 2015 06:23 AM
WDScott
Aug 17, 2015 06:38 AM
fl_799
Nov 10, 2006 12:30 AM
Stang Skeleton
Aug 13, 2006 07:37 PM
