Door panel insert repair/replace
Old Aug 17, 2010 | 05:40 PM
ThisBlood147's Avatar
ThisBlood147
Question Door panel insert repair/replace
My car has survived 4 super hot summers down here in southeast Louisiana, and the heat has finally taken its toll. The leather coverings over the door inserts have begun to fall away from the door....the adhesive apparently having melted. I'm looking for input from anyone who has had to deal with this repair before (or has reskinned these inserts themselves). How hard is it to get the inserts themselves off? Secondly, what kind of adhesive should I be looking to use (since this is going to be exposed to my car's hot interior)?
And finally, where can I find some aftermarket replacement inserts? (just in case my self repair does not go well).
Old Aug 17, 2010 | 06:34 PM
Shadow7874's Avatar
Shadow7874
There is a DIY on this exactly somewhere on the forums but all you need is the high quality 3M adhesive spray and just glue it back pretty much. Just get the high temp rated stuff
Old Oct 19, 2011 | 05:42 PM
bobl_34997's Avatar
bobl_34997
I tried this and it's a temporary fix. Part of the issue is the foam behind the leather panel is deteriorated and so no adhesive will stick until it makes good contact to the material beyond the deteriorating foam.
Spray adhesive will work for a while and you may want to go this route. But, I am going to try the repair suggested in the forum that pulls down the leather, rubs the deteriorating foam off and then uses contact cement on both sides.
Old Oct 19, 2011 | 05:44 PM
mustang0672's Avatar
mustang0672
On my dads 2006, he had the same problem. The dealership we go to fixed it...then again we have one of the best Ford dealerships around.
jerrytubes
Oct 23, 2015 12:11 PM
b8checker
Oct 8, 2015 12:55 PM
jrrhd73must
Oct 2, 2015 09:17 PM
b8checker
Sep 30, 2015 07:11 AM
