Mustangforums UNITE and please help :(
I recently purchased the steeda underdrive pulleys for my 2006 mustang gt. I Have a 93 octane tune, BBK air intake and Pype bomb axle backs. I installed my underdrive pulleys exactly the way Taco Bill's write up says. (My car is an automatic) I got everything put back together then the car would not start. I turned it off and tried it again and the car started and went to about 2200 rpms then rpms dropped and the car died. I tried to crank it a few more times, sometimes it would crank and die, sometimes it would just not crank. I'm completely stumped guys and I'm in need of some serious help. Can you all tell me whats the problem? thanks
I double checked, could this be caused from my air intake not on all the way? maybe i should retune my car?
Yes I would defintely say your intake not being installed all the way would cause the problem. The MAF will not read correctly if at all. You shouldn't need to retune unless you now have the check engine light on. Although, it's not going to hurt anything and if it gives you peace of mind then retune away. Good luck. Hopefully it's just the intake.
Recheck all your connections and drive the car for 10 miles. If check engine light is still on check your connections again and make sure the belt is on properly.
