new ebrake cable, still doesnt work
Old Sep 20, 2010 | 07:12 PM
steve r's Avatar
steve r
Default new ebrake cable, still doesnt work
Ok so my front ebrake cable snapped. So I ordered a new handle with cable attached to it. I just got finished installing it and It clicks up but doesnt hold at all. It snapped because the calipers froze over the winter. Do you guys think I am going to need to get new calipers or what? Im lost here, thanks
Old Sep 20, 2010 | 09:58 PM
2005Redfire6's Avatar
2005Redfire6
They may sound stupid but did you reconnect the replacing ebrake with the existing cable...? And did you tighten the cable with the tensioner type device under the center console?
Old Sep 20, 2010 | 10:07 PM
steve r's Avatar
steve r
I installed a new ebrake handle witch comes with a new cable which connects to the two rear ebrake cables. Im guessing I need new calipers because they are still frozen or something. Or I need new rear cables. I never knew an ebrake would be this much of a pita
Old Sep 21, 2010 | 05:17 AM
2005Redfire6
I don't know how your calipers will remain frozen, why don't you run it by Just Brakes or some other similar shop. Sounds like it would be a cheap fix or they can atleast tell you whats wrong with it.
Old Sep 21, 2010 | 07:57 AM
steve r's Avatar
steve r
im not saying theyre still frozen from the water, I mean like maybe because it sat for 7 months they locked up or something?
Old Sep 21, 2010 | 08:07 AM
Boondoggie's Avatar
Boondoggie
You didn't replace the rear cables?
The rear cables are the part that freeze in the winter. You're blaming the wrong part for the freezing.
TSB 06-5-4 is the TSB describing the frozen ebrake, and what parts are the culprit.
Old Sep 21, 2010 | 09:09 AM
steve r's Avatar
steve r
[QUOTE=Boondoggie;7209100]You didn't replace the rear cables?
TSB 06-5-4 is the TSB describing the frozen ebrake, and what parts are the culprit.[/QUOTE
Yes I know the rear cables are the tsb, but I thought they make the calipers freeze? But if just the front cable snapped, shouldnt the rear cables still be good? just in the winter there is a risk of them freezing again.. I know I probably need new rear cables or calipers I just dont know which
Old Sep 21, 2010 | 09:14 AM
steve r's Avatar
steve r
I just read the tsb again and yea I was wrong, i thought it said it caused the calipers to freeze. Ok so I guess I gotta change both my rear cables now. For some reason I thought it said that the boot on the rear cables can allow water it and some how freeze the calipers. I didnt know it actually cause the cables to "bind up"
Pyrate Dave
Sep 10, 2015 07:30 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
cbird1177711
Sep 3, 2015 08:43 PM
