AXLE RATIO DIFFERENCES
Old Sep 29, 2010 | 01:39 PM
brazeagle's Avatar
brazeagle
Question AXLE RATIO DIFFERENCES
Hello All,
I am still building my GT and I was wondering what are the differences among axle ratio?
I was offered to go with the 3.73, but I do not know what it means in terms of performance improvement, gas mileage and if it is really necessary. What does axle ratio do to the vehicle?
Thank you and soon I will be more knowledgeable in the world of MUSTANG.
Please appreciate any inputs.
Drive Safe
LCL
Old Sep 29, 2010 | 01:50 PM
soonerwarren's Avatar
soonerwarren
3.73 gears i believe will give you worse mileage, but makes your car accelerate faster. It also makes your top end a little less because the gear are smaller, which is why it makes the car faster.
Old Sep 29, 2010 | 01:59 PM
2cokeman's Avatar
2cokeman
3.55s are good enough for everyday driving, the diff. will be negligable!
Old Sep 29, 2010 | 02:03 PM
brazeagle's Avatar
brazeagle
Excellent,
I am sure I will not notice the difference for normal driving, so I guess I will save some money and stay with the stock option, since mileage is a a consideration for me.
Thanks
LCL
Old Sep 29, 2010 | 02:31 PM
onederful100's Avatar
onederful100
1st, you should determine what your gear ratio is now.
Old Sep 29, 2010 | 03:23 PM
thedrod's Avatar
thedrod
You'll definitely accelerate faster having 3.73:1 or 4.10:1 over a 3.55:1 ratio. Your RPM at highway speed will be higher though resulting in slightly reduced miles per gallon. Totally worth it in my opinion.
Old Sep 29, 2010 | 03:58 PM
JDWalton's Avatar
JDWalton
he said he is still building it, dont they come real low in the base setup? I say go with the 3.73. Its a very good all around gear and will hold you over from feeling you HAVE to have 4.10s for a while.
Nuke's Avatar
Nuke
Fuel mileage impact is minor, depending on how you're driving. Figure roughly taking about a 1 MPG hit cruising steady highway with 3.73's as opposed to 3.55's and another maybe 1 MPG as opposed to 3.31's. But you're not buying the car for economy so phoeey to THAT.
Quicker off the line with higher ratio and top-end is NOT impacted. You'll reach the cars limit due to the coefficient of friction (drag) before you'll limit out on gear.
Old Sep 29, 2010 | 04:58 PM
alkemist's Avatar
alkemist
The higher the gear ratio, the faster delivery of the torque. Really depends on how you want to drive your stang. Mine is a daily driver and I have 4.10 gear ratio.
Old Sep 30, 2010 | 07:32 AM
brazeagle's Avatar
brazeagle
Thank you everyone,
The base on the GT Premium (400a package) comes with 3.31 axle ratio, and if you add a 3.55 or a 3.73 the price increases 395US. The problem is not the 395, it is mostly if I will really feel the difference and if the mileage is really a factor from 3.31 to 3.73 since I will not use the car in TRACKS, it will be a daily drive or a weekend drive only.
Thank you
LCL
