how do i know if??
Old Oct 3, 2010 | 09:49 PM
deekum1627's Avatar
deekum1627
Default how do i know if??
my 02 senors is def bad i got a check engine light my code is p0430.
Old Oct 3, 2010 | 10:19 PM
SpartaPerformance's Avatar
SpartaPerformance
Anything done recently? This code has a few possible causes other then the o2 sensor itself.
• Out of range engine coolant temp sensor
• High fuel pressure
• Damaged exhaust manifold
• Damaged catalytic converter
• Oil contamination
• Cylinder misfiring
• Downstream O2 sensor wires incorrectly connected
• Damaged exhaust system pipe
• Damaged muffler/tail pipe
• Retarded spark timing
• Leaking injector
If it turned out after the tune tell Dan to do it over.
Old Oct 4, 2010 | 11:23 AM
deekum1627's Avatar
deekum1627
i had new cats put on and a new 02 senors for one of them, then i had a custom dyno tune from dan but i was fine for well over a few hundred miles
Old Oct 4, 2010 | 11:36 AM
157dB's Avatar
157dB
Cut & Paste Expert
http://iihs.net/fsm/?dir=10&viewfile...scriptions.pdf
Or buy an MSD DashHawk and see the O2 sensor reading realtime...
Old Oct 4, 2010 | 11:54 AM
deekum1627's Avatar
deekum1627
thanks 157db.
sparta where on LI are you?
