separator plate ?
Old Oct 4, 2010 | 08:19 AM
steve r's Avatar
steve r
Default separator plate ?
When the weather is cold out and I start my car when the car is also cold I keep hearing something that sounds like something is hitting my flywheel... Sure enough I do a quick search and I find a tsb on the separator plate problem. My question is, if I dont get it fixed, will it cause more damage? thanks
Old Oct 4, 2010 | 08:20 AM
2005Redfire6's Avatar
2005Redfire6
Is it like a noise that sounds like a bell, metal on metal?
Old Oct 4, 2010 | 09:41 AM
JDWalton's Avatar
JDWalton
IF it is seperator plate buzz, no it will not cause any damage. It is a anoying sound I know. When I did my clutch after the "repair" it appears all they do is take the seperator plate and use a punch to create a small crease in it. That makes it so the plate has to be pressed flat when the transmission ins installed and the buzz goes away.
Old Oct 4, 2010 | 11:15 AM
steve r's Avatar
steve r
it sounds like something is is spinning and another metal part is scraping it.. only when the car is cold tho
Old Oct 4, 2010 | 11:22 AM
JDWalton's Avatar
JDWalton
sounds like it.
Old Oct 4, 2010 | 11:23 AM
2005Redfire6
I have a similar sound but mine does it whenever the clutch is engaged, same problem?
Old Oct 4, 2010 | 11:25 AM
steve r's Avatar
steve r
mine does it with the clutch pushed in, or when the clutch is left alone
Old Oct 4, 2010 | 11:47 AM
2005Redfire6
I think we have a different issue then because the only time mine doesn't do it is when the pedal is pushed in, and it only does it at low RPMs when the clutch is out.
Old Oct 4, 2010 | 02:29 PM
steve r's Avatar
steve r
yours sounds like your throwout bearing is going
Old Oct 4, 2010 | 10:26 PM
SpartaPerformance's Avatar
SpartaPerformance
I have the separator plate noise in my car too, had it since new hasn't blown up..............yet!
