Question on K & N Air Filter
Hi all,
I have a question as I am thinking about adding a K & N air filter to the factory CAI that came with my '10 Mustang GT.
K & N advertises that their air filters add horsepower to any engine you put them on. The only issue I have with that statement if that they don't say how much HP they add. Does anyone know how many more ponies I'll get by adding the K & N air filiter? My GT is completely OEM, with the 4.6 V8 currently giving me 315 HP with 325 ft lbs of rear wheel torque since I use premium gas.
Any answers would be appreciated. Thanks.
If you are looking to gain HP, get a Cold Air Intake and Tuner combo with a tune from somewhere like AmericanMuscle or Brenspeed.
I would count on the K&N giving you squat as far as HP.
Your stock 10 Mustang is NOT putting down 315HP to the wheels, that is what it is rated at to
the crank. Regardless of you using premium fuel or not.
You are going to be running about 268HP or so to the wheels.
I once swapped in a K&N filter when I still had the stock air box. All I noticed was some smoother engine response at best, and that could've just been in my head. The real selling point of the K&N filter is that it's re-usable, so you save money in the long run.
Drop-ins are useless. Spend the money on a proven power adder; CAI & custom tune. ANY change to the intake that doesn't require retuning is wasted money.
You must be pretty young since you actually BELIEVE advertised HP gains. Next thing we'll see is a TB spacer on your engine...
You wont notice anything with a K&N until it gets oil on your mass air sensor and throws a code. They do allow better air flow for about 2 hours but after that...notta! Get a cai/tune package or replace the paper filter on a regular basis.
Don't buy into the bs pal...k&n is and always has been a joke and might get you better throttle response for a short period of time, but hp gains...forget about it.
Ultimate getto mod list:
K&N drop in
Tornado intake insert
Throttle body spacers
ect, ect....starting to get the idea?
K&N drop in
With any stand alone CAI, you may only see 3 - 5 HP increase. When I installed my Airaid CAI, which does not require a tune, I felt a little more throttle response in the higher RPM ranges. The performance adder is mainly in the custom tune. I would highly recommend a tuner and custom tunes from Brenspeed or American Muscle, which are two very reputable companies.
Good luck!
Good luck!
You have a stock CAI, and according to AM it is more than enough for a 2010. Somewhere around 840 cfm is what it flows. I just used a drop in K & N and Bama tuned. I use the 93 octane "race" tune. That is about all I need.
There's a thread on this forum where a 2010 was dyno'd with the stock CAI and an aftermarket CAI, the difference was something like 4hp.
I kept the factory intake and just did the tune, saving a couple hundred bucks.
