removing carpet to put in sound deadening mat?
Old Nov 6, 2010 | 07:53 PM
danzcool's Avatar
danzcool
Default removing carpet to put in sound deadening mat?
So, I am putting in sound deadening mat this weekend and removed the trim panels, center console, seats, etc....
Anyway, I get to what I had expected was where I had to be to remove the carpet to get to the floor, and it looks like a section of carpet connects the passenger to drivers side underneath the center stack (stereo, HVAC, etc.), so, is there an easy way to remove that, or should I just cut the carpet there and throw a little glue or double stick tape there when putting it back? The section I would cut would be behind the trim panel, so i can't really see any down side there, just would rather not do it if it is easy enough to remove the center stack.
Old Nov 7, 2010 | 09:10 AM
157dB's Avatar
157dB
Cut & Paste Expert
deaden what you can get to and call it good.
maybe THIS WILL HELP?
Attached Thumbnails removing carpet to put in sound deadening mat?-dynamat.jpg
Old Nov 7, 2010 | 09:51 AM
Boozshey's Avatar
Boozshey
Yeah, don't cut the carpet. you will only be missing out o about a 12" section by not doing that. Unless you really want to remove the dash to get to it.
This is what you will see if you do...
Old Nov 7, 2010 | 10:09 AM
danzcool's Avatar
danzcool
Yeah, I used those online manuals to get everything removed so far, they are great.
And I did some a few hours of searching here last night and everyone has said just cut the 2 - 2" connecting strips of carpet under the center stack. I certainly don't want to get into all the electronics of the dash, especially since I didn't even expect the carpet to be under there. Any way, thanks, time to git'r done.
drfister
May 3, 2018 10:38 PM
MonsterBilly
Sep 19, 2015 08:50 PM
69FB
Aug 18, 2015 08:50 PM
kirk35
Aug 17, 2015 08:42 PM
