DING sound at low speeds?
Hello, i have a 2005 Mustang GT 5 speed...
only mod im aware of is a cold air intake...
at low speeds there is this ding sound? when i stop abruptly or take off... i took it in and they said my U-joint is bad... bull ****... i checked it and it was fine, no shaking or rattling, it just sounds like someone is dropping a wrench on the drive shaft, it sounds like its coming from right behind the rear seats on the passenger side
any suggestions?
will add additional info upon request
any suggestions?
any suggestions?
any suggestions?
Is it a ding or more of a metal grinding type sound at a very narrow RPM range? If so, I'll also go with exhaust rattle. That may be fixed by tightening the axleback-to-midpipe clamps another 1/4 - 1/2 turn.
There are quite a few known under-chassis rattle causes on the S197's.
yes im sorry... i forgot, i had flow masters installed not 2 long ago. i will definitely check that when i get home... and yes like i said its like someone dropped a wrench on the drive shaft. like dinggg ding ding ding and some grinding..
There are a few exhaust related rattles, some issues with heat shields vibrating and TSB for a tranny separator plate (or something to that effect) that are known under carriage rattles.
Keep us posted on what you find.
YO, 2005Redfire6! Maybe I should ask the OP if it might be related to the water leak...
found the issue... believe it or not i had a piece of re-bar in my rear tire 0.o dont ask how this happened... i guess it would fall and smack the inside of the rim?
but it hasnt done it since
musnicki
Sep 23, 2015 07:11 AM
