So after being on the fence for quite a while, I decided to just go ahead and buy the whipple HO kit. Being that I have cams and long tubes I would like to run a bigger pulley to create less boost. Does anyone know what size the pulley the non intercooled kit uses? looking to make around 7psi to start
I will take the install slow as the car is off the road for the winter, but I will absolutely take alot of pictures and post them up. Anyone have links on relocating the IAT sensor? and what gauges are you guys using?
Who did your tune? I have a similar setup, Hot rod cams, and pypes LT's. I plan on getting a dyno tune but I want someone with experience on similar set ups
Toronto is a little far for you to come (LOL), but I had my Custom Dyno Tune (not a canned tune) done by Steeda CA here. It's running really strong..!!!
