I NEED HELP !!
Old Dec 18, 2010 | 03:10 PM
Q8-GT's Avatar
Q8-GT
Default I NEED HELP !!
Hey guys,
I have a 2005 whipple'd mustang gt , last week the car was in " fail safe engine mode " and it was Horrible . I cleaned the air intake and the throttle body and flashed the car , after doing that the car was perfect and running good ! Until a few days ago ! I started the car , drove it for 2 or 3 miles , then it suddenly stopped and showed these codes " fuel level low , check charging system , dte odo data err " and it wouldn't start again !
Any idea ??
Old Dec 18, 2010 | 03:39 PM
hammeron's Avatar
hammeron
if reflashing the tune doesn't help again, i might suspect a throttle body or throttle
position sensor problem. good luck i hope you can get it sorted out.
Old Dec 18, 2010 | 08:05 PM
Q8-GT's Avatar
Q8-GT
I reflashed the tune again and didn't work , and I've experienced many problems with my BBK 62mm throttle body ! So I think I'm gonna change it .
What do u suggest me to replace it with ?
Old Dec 18, 2010 | 08:08 PM
SpartaPerformance's Avatar
SpartaPerformance
I use a GT-500 TB with spacer plate. They come with electronics already connected and calibrated.
Old Dec 18, 2010 | 08:19 PM
BruceH's Avatar
BruceH
Won't fit with a Whipple.
OP, when was the last time you changed your plugs?
Old Dec 18, 2010 | 08:25 PM
nbates723's Avatar
nbates723
i bet it has something to do with your tune. i just put a tune on mine last weekend and that was showing on the display while it was uploading
Old Dec 18, 2010 | 08:47 PM
Q8-GT's Avatar
Q8-GT
The plugs r new ! Just changed them
When I flashed the tune the first time , I took the car to the dyno and everything was perfect ! I don't think it's from the tune !
Old Dec 18, 2010 | 09:59 PM
bakerjd's Avatar
bakerjd
why all the exclamation points?!...lol, hope things end up working out for you. i'd hate to see someone not enjoy their mustang as much as most of us on the forums
Old Dec 19, 2010 | 12:23 PM
SpartaPerformance
And why exactly wont it fit the Whipple?
