Steering Wheel Vibration - 2010
Just started noticing the steering wheel shake on my 2010 GT. Seems to be there from somewhere around 40 MPH to 60 MPH. It is really noticeable if you let go of the wheel.
Has anyone had any luck with this common issue on the S197 being resolved by your dealer? I figure I will take it in for the free balance and alingment and see what happens, just wanted to see if anyone had another cause I could bring up while I was there.
If you're running the OE tires and wheels, then certainly have the dealership rebalance AFTER you make sure the wheels are properly seated against the rotors and the lugs torqued correctly. If you're running aftermarket wheels, be sure the rotor clips have been removed from any of the wheel studs.
If it persists, insist they do a RoadForce balance.
I think every one of these steering issues has been tire/wheel related but mine was actually a bad inner tie-rod. I disconnected the tie rod ends from the spindle and could pull/push the drivers side about 1/8'' in/out of the steering rack. Bad tie-rod joint. Tight as a prom queen now. Just something else to have checked...
I dont know about the 05-09's, but it seems VERY common on the 10's for sure. Mine did it with the stock 19's on it. Then I changed to 20's and it still does it. I had every kind of balance you can imagine. Still there. The tabs from the rotors are also gone. Still there. Alingment, etc. Still shakes.
At this point it really doesnt bother me, so I stopped chasing it. But you would think Ford could build these so they wouldnt shake. I suspect that is the reason Ford went to electric steering on the 11's. They probably just tuned it out with the electric system.
I'm totally stock, 18" wheels.
I am going to call the dealer tommorow and get it in there. I will try and make them do a road force balance, though honestley I do not know enough about that system and how available it is in my area.
In my head, if it does not happen on every 2010, then it should be something that can be fixed right?
I dont know about the 05-09's, but it seems VERY common on the 10's for sure. Mine did it with the stock 19's on it. Then I changed to 20's and it still does it. I had every kind of balance you can imagine. Still there. The tabs from the rotors are also gone. Still there. Alingment, etc. Still shakes...
Excellent, very very few people know that and end up chasing shakes endlessly.
You may have the same issue of it being your wheels, aftermarket wheels are horrible I don't care who makes them or how much they cost, not to mention they're not always the right offset and backspacing then you add wider tires that alone adds a whole bunch of issues that can make it shake including an alignment if the tech doesn't know how to compensate.
Even my '07 has it and I've had the RoadForce balance, clips removed (despite running OE GT500 takeoffs which aren't affected by the clips), yada-yada. It's there but I've learned to live with it and others with 05-09s have it, too. And since the '10 is no different then you're in the same boat. Then again, this isn't my first car that had a unidentifiable vibration. I suspect it's more of a drive train issue at this point. And quite a few 11' owners have already been stating that they have vibe issues.
