plug n play instrument cluster?
Hey guys well I am a victim of the faulty stepper motors in the 2005 mustangs where they die... So I got a new one on the way, is it plug and play as far as mileage reading out on the display? I would imagine so. Its a 4 gauge cluster if that makes a difference.
As I understand it this will need to be the same exact dang near everything I thought, or the PATS barfs and ya can't start it with that one plugged in until it's set right at the stealership.
Mileage will show, but it will show what that cluster has seen mileage wise, not what your car's computer has seen or the previous cluster has. So if your old cluster shows 48k miles, this new one only has 22k, it will only show the 22k.
And come on...What happened to the mycolor swap? Cheap bastid.
Thanks guys, I actually bought one new from the dealership cause the ones I've seen on eBay are sold as is and not sure if they are working. They also have 2005 clusters for sale and that will just give me the same issue down the road, when it comes in I will have them transfer my mileage!
https://mustangforums.com/forum/2005...t-working.html
http://www.mustangcollective.com/sho...cluster+repair
Thats the tutorial on how to fix it... I tried and failed.
The cluster needs to ORDERED it with the correct Mileage ... It can only be set by the Manufacturer ... or a Speedometer shop. There is a Speedo Shop in Alpharetta that quoted me $150 to set the Odometer.
