Dumb Question...
Old Jan 23, 2011 | 09:09 PM
tdurham19's Avatar
tdurham19
Default Dumb Question...
I have a 2006 v6 auto and there is an overdrive button on the shifter. What is overdrive and what does it do?
Old Jan 23, 2011 | 09:38 PM
AlloySixxer's Avatar
AlloySixxer
Overdrive activates the turbo boost.
Old Jan 23, 2011 | 09:49 PM
2005Redfire6's Avatar
2005Redfire6
Lol @ Nick...
Overdrive is like a cruising gear... Your 5th gear.
Old Jan 23, 2011 | 10:00 PM
Alec's Avatar
Alec
Overdrive is a 1:1 gear, for highways and for fuel economy
If you have some time on your hands:
http://en.wikipedia.org/wiki/Overdrive_%28mechanics%29
Old Jan 23, 2011 | 10:02 PM
bakerjd's Avatar
bakerjd
haha! Follow Alec's advise and don't forget
Old Jan 23, 2011 | 10:09 PM
daredevil95's Avatar
daredevil95
The 1:1 gear ratio lowers the the engine speed (rpm) when driving at highway speeds....55mph or over. The lower engine speed reduces fuel consumption. So, when you speed up hit the button and when your slowing down turn it off. I would leave it on all the time.
Old Jan 23, 2011 | 10:14 PM
dean12692's Avatar
dean12692
is it bad to drive w/ overdrive constantly on?
Old Jan 23, 2011 | 10:22 PM
alkemist's Avatar
alkemist
As mentioned above.. over drive is your 5th gear. Depends if you want to drive with 5th gear or not, but usually it's something you keep on. 1st, 2nd,3rd, D (4th), OD (5th) gear.
If you feel up to it, you can even manually upshift your auto. It can be fun, just don't skip gears, the stock shifter doesn't like to lock itself
Old Jan 23, 2011 | 10:35 PM
JIM5.0's Avatar
JIM5.0
Actually, the overdive gear is not the 1:1 gear, it is a gear that is lower than 1:1. Just like said above, it is a cruising gear and is meant for top speed or highway fuel economy.
If you turn off your overdrive button, what you do is you cause your tranny to lock out the overdrive gear (or gears, if there is more than one) so that the highest gear your car will shift into is the 1:1 gear.
I think on the 5speed automatic, the 4th gear is the 1:1 gear and the 5th is the overdrive, and hitting that switch locks out 5th gear.
On a manual, of course, there is no overdrive button, if you do not want to go into an overdrive gear, you simply do not shift into it.
Old Jan 24, 2011 | 04:15 AM
Blacksmoke's Avatar
Blacksmoke
The Paranoid One
Overdrive in car language translates into
"Oughtabedrivinamanual"
;P
